D14 Series Engines (1.4 Liters)
D14A1
Found in:
1987-1991 Honda Civic GL and 1990 CRX (European Market)
Displacement : 1,396 cc (85.2 cu in)
Bore and Stroke : 75.0 mm × 79.0 mm (2.95 in × 3.11 in)
Compression : 9.3:1
Power : 90 hp (67.1 kW, 91.3 ps) @ 6300 rpm
Torque : 83 ft·lbf (11.5 kg/m, 112 Nm) @ 4500 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : Dual Carburetor
D14A2 (non- vtec)
Found in:
1995-1996 Honda Civic MA8 (European Market)
Compression : 9.2:1
Power : 89 hp (66.4 kW, 90.2 ps) @ 6100 rpm
Torque : 86 ft·lbf (11.9 kg/m, 117 Nm) @ 5000 rpm
Fuel Control : Multi-point fuel Injection, PGM-FI
D14A3 (non- vtec)
Found in:
1996-1999 Honda Civic EJ9 (European Market)
Compression : 9.1:1
Power : 75 hp (55.9 kW, 76.0 ps) @ 5700 RPM also 90 hp
Torque : ? ft·lbf (? kg/m, 112 Nm) @ 3000 rpm
Redline : 6800 rpm
Fuel cut: 7200 RPM
Fuel Control : Multi-point fuel Injection (PGM-FI)
Transmission: S40
D14A4 (non-vtec)
Found in:
1996-2000 Honda Civic EJ9 (European Market)
Compression : 9.2:1
Power : 90 hp (67.1 kW, 91.3 ps) @ 6400 rpm
Torque : ? ft·lbf (? kg/m, 124 Nm) @ 4800 rpm
Red line : 6800 RPM
Fuel cut: 7200 RPM
Transmission: S40
The D14A3 and D14A4 engines are identical, the difference is only one small gasket under the throttle body in D14A3 which restricts the air intake of the engine.
D14Z4
Found in :
1996-2001 Honda Civic 5 Door HB , MB2
Fuel Control: Multipoint Fuel Injection (PGM-FI)
Transmission: ?
Power Output: ?
(Added after the info provided by our member MB2civic )
D15 Series Engines (1.5 Liters)
D15A2
The JDM spec engine model of one of the EW series motors, used in later years of the third-gen Civic.
D15A3
Found in:
1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ)
Displacement : 1,488 cc (90.8 cu in)
Bore and Stroke : 74 mm × 86.5 mm (2.9 in × 3.4 in)
Compression : 8.7:1
Power : 91 hp (67.9 kW, 92.3 ps) @ 5500 rpm
Torque : 93 ft·lbf (12.9 kg/m, 126 Nm) @ 4500 rpm
Valvetrain : SOHC (3 valves per cylinder )
Fuel Control : PGM-FI2
D15B
VTEC
Found in :
1991-1995 Honda Civic VTi EG4 (Japanese Market)
1991-1995 Honda Civic VTi EG8 (Japanese Market)
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke :75,0×84,5 mm
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9,3:1
Power : 115 hp (85.7 kW, 115 ps) @ 6800 rpm
Torque : 103 ft·lbf (14.1 kg/m, 138 Nm) @ 5200 rpm
Redline : 7200 rpm
Rev-limiter : 7411 rpm
Valvetrain : SOHC VTEC (4 valves per cylinder)
VTEC Switchover : 5000 rpm
Head Code : P08
Piston Code: P08-010
Fuel Control : OBD-1 PGM-FI
D15B (3 stage VTEC)
3-stage VTEC
Found in:
1995-1999 Honda Civic VTi EK3 and Ferio Vi
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 125hp (93.2 kW, 127 ps) @ 6800 rpm
Torque : 104@ 5300 rpm
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on rpm)
VTEC Switchover : 2500 rpm (VTEC-E) & 6000 rpm (VTEC)
Fuel Control : OBD-2 MPFI
D15B
Found in :
1988 Honda CRX 1.5X (rare)
Honda Civic Ferio MX (Japanese Market)
1998-2001 Honda Capa GA4 (Japanese Market)
Compression : 9.2:1
Power : 106 hp (96.9 kW, 105 ps) @ 6500 rpm
Torque : 95.4 ft·lbf (13.2 kg/m) @ 4500 rpm
Rev limiter : 7400 rpm
D15B1
(Same as the D15B2 engine, but with a mild camshaft, and a restrictor plate between the throttle body and intake manifold)
Found in:
1988-1991 Honda Civic Hatchback
Compression : 9.2:1
Power : 70 hp (52.2 kW, 71.0 ps) @ 5500 rpm [1]
Torque : 83 ft·lbf (11.4 kg/m, 112 Nm) @ 3000 rpm [2]
Fuel Control : OBD-O DPFI
Head Code : PM3
ECU Code: PM9
D15B2
Found in:
1988-1991 Honda Civic GL/DX/LX
1988-1991 Honda CRX DX
1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
1990-1995 Honda Concerto (European Market)
Rod Length : 134 mm
Compression : 9.2:1
Power : 92 hp (68.6 kW, 93.3 ps) @ 6000 rpm
Torque : 88 ft·lbf (12.2 kg/m, 119 Nm) @ 4500 rpm
Cam Gear : 38 tooth
Piston Code : PM3
Redline : 6500 rpm (6000 rpm Honda Concerto) 7200 rpm rev limiter
Head Code : PM3
ECU Code: PM5
D15B3
Found in:
1988-1989 Honda Civic EX
1988-1995 Honda Civic Shuttle GL
1992-1995 Honda Civic LX (NZ model)
1988-1991 Honda Civic LX (NZ model)
1992-1995 Honda Civic EX (SA model)
Compression : 9.9:1
Power : 93 hp (69 kW, ? ps) @ 6000 rpm
Torque : ? ft·lbf (? kg/m, 121 Nm) @ 4500 rpm
Cam Gear : 38 tooth
Fuel Control : Carburetor
D15B4
Found in:
1989-1991 Honda Civic GL (Australian Market)
Compression : 9.2:1
Power : 96.5 hp (72kW) @ 5200 rpm
Torque : 90 ft·lbf (12.4 kg/m, 122 Nm) @ 3800 rpm
D15B6
Found in:
1988-1991 Honda Crx HF
Compression : 9.1:1
Power :
['88-'89] 62 bhp (46.23 kW, 62.86 ps) @ 4400 rpm
['90-'91] 72 bhp (53.7 kW, 73.0 ps) @ 4500 rpm
Torque : 83 ft·lbf (11.5 kg/m, 113 Nm) @ 2200 rpm
Valvetrain : 8-Valve SOHC
Fuel Control : OBD-0 MPFI
Head Code : PM-8
D15B7
Found in:
1992-1995 Honda Civic CX (Canadian model)
1992-1995 Honda Civic DX/LX
1993-1995 Honda Civic del Sol S
1992-1995 Honda Civic LSi Coupe (European Market)
Compression : 9.2:1
Power : 102 hp (76.1 kW, 103 ps) @ 6200 rpm
Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 3800 rpm
Cam Gear: 38 Tooth
Piston Code : PM3
Fuel Control : OBD-1 MPFI
ECU Code: P06
D15B8
Found in:
1992-1995 Honda Civic CX (U.S. model)
Displacement : 1,500 cc (91.5 cu in)
Compression : 9.2:1
Power : 70 hp (52.2 kW, 71.0 ps) @ 4500 rpm
Torque : 83 ft·lbf (11.5 kg/m, 113 Nm) @ 2800 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-1 MPFI.
D15Z1
VTEC-E
Found in:
1992-1995 Honda Civic VX
1992-1995 Honda Civic VEi (European Market)
Bore and Stroke :75 mm × 84.5 mm (3.0 in × 3.3 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.3:1
Power : 90 hp (67.1 kW, 91.3 ps) @ 5600 rpm
Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 4800 rpm
Valvetrain : SOHC VTEC-E (3-4 valves per cylinder depending on RPM)
ECU Code : P07
D15Z4
Found in:
1996-2000 Civic Exi and SA Ballade & Civic 150i
Power : 90 hp (67.1 kW, 91.3 ps) or 105 hp @ 5800 rpm
Torque : 99-103 ft·lbf (14 kg/m, 134-140 Nm) :confirm?]] @ 4200 rpm
D15Z6
VTEC-E
Found in:
1995-2000 Honda Civic 1.5 iLS (European Market)
Rod Length : 137 mm
Compression : 9.6:1
Power : 114 hp (84 kW) @ 6500 rpm
Torque : 99 ft-lb (134 Nm) @ 5400 rpm
VTEC Switchover : depending on load, max ~3500 rpm in 5th gear
Fuel Control : OBD2 PGM-FI MPFI
D15Z7
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 128 hp (95.4 kW, 130 ps) @ 7000 rpm
Torque : 102 ft·lbf (14.2 kg/m, 139 Nm) @ 5300 rpm
VTEC Switchover : ? rpm
ECU Code : P2J
D15Z8
VTEC-E
Found in:
1997-2000 Honda Civic LS (European Market)
Compression : 9.6:1
Power : 114 hp (85.0 kW, 116 ps) @ 6500 rpm
Torque : error?: 95-99 ft·lbf (13-14 kg/m, 128-134 Nm) :confirm? @ 4500 rpm
Head Code : P2J
ECU Code : P2P
Valvetrain : SOHC VTEC-E (4 valves per cylinder)
Fuel Control : OBD2 MPFI
D16 Series Engines (1.6 Liters)
D16A1
Found in:
1986-89 Acura Integra (USA)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Valvetrain : DOHC (4 valves per cylinder)
1986-1987
Compression : 9.3:1
Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm
Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500 rpm
Piston Code: PG6
1988-1989
Compression : 9.5: 1
Power : 120 hp (88.0 kW, 120 ps) @ 6250 rpm
Torque: 101 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm
Piston Code: P29 (Equivalent to PM7)
ECU Code: PG7
D16A3
Found in:
1986-89 Acura Integra (Australia)
Compression : 9.5:1
Power : 118 hp (88.0 kW, 120 ps) @ 5600 rpm
Torque : 103 ft.lbf (14.3 kg/m, 140 Nm) @ 4800 rpm
Valvetrain : DOHC, 4 valves per cylinder
D16A6
Also known as D16Z2.
Found in:
1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
1990-1991 Honda Civic EX Sedan
1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
1989-1996 Rover 216/416 GSi/Tourer (UK/Europe)
Rod Length : 137 mm
Rod/Stroke : 1.52
Compression : 9.1:1
Power : 108 hp (80.5 kW, 110 ps) @ 5600 rpm
Note: 1988-89 engines were 105 hp (78.3 kW, 107 ps)
Torque : 100 ft·lbf (13.9 kg/m, 136 Nm) @ 4,800 rpm
Redline : 6500 rpm (USA)
Head Code : PM3
ECU Code : PM6
D16A7
(Basically a D16A6 that came without a catalytic converter, like the European version of the D16A6)
Found in:
88-89 Civic models in Europe(ED4,ED7)
88-95 Models in South Africa
Ballade SH4 and SR4 ( D16A7 / EE4 )
Compression : 9.6:1
Power : 115 hp (85.8 kW, 117 ps) @ 5900 rpm
Torque : 100 ft·lbf (13.9 kg/m, 136 Nm) @ 4800 rpm
Fuel Control : OBD-0 Multi-point PGM-FI
D16A8
Found in:
1988-1995 Civic/CRX/Concerto (UK/Europe/Australia)
1992-1995 Rover 216/416 GTi(UK/Europe)
1993-1997 Rover 216 SportCoupe (Europe)
Compression : 9.5:1
Power : 125 hp (93.2 kW, 127 ps) @ 6800 rpm
Torque : 108 ft·lbf (14.9 kg/m, 146 Nm) @ 5900 rpm
ECU Code : PP5
Gearbox : L3
Runs on Hopes and Dreams
D16A9
(Same as D16A8 but without a catalytic converter)
Found in:
1988-1991 Concerto (UK/Europe)
1988-1991 CRX 1.6i-16(UK/Europe/South Africa)
1988-1991 Civic 1.6i-16(UK/Europe/South Africa)
1989-1992 Rover 216/416 GTi (UK/Europe)
1992-1995 Civic Si (Peruvian version)
Compression : 9.5:1
Power : 130/137 hp (96.9 kW, 132 ps) @ 6.800 rpm
Redline: 7200 rpm
Limit: 7800 rpm
Fuel Control : OBD-0 MPFI (92-95 OBD-1)
ECU Code: PM7 (92-95 P29)
GearBox : L3 Cable type (92- 95 S20)
D16B5
(Identical to the D16Y5. Main differences are Pistons, Rods, Camshaft, Head Gasket, Intake Manifold, and Exhaust Manifold are PDN rather than P2M)
Found in:
1998-2000 Honda Civic GX
Rod Length : 137 mm
Compression : 12.5:1
Combustion Chamber Volume : 32.8 cc per cylinder
Power : ? hp (? kW, ? ps) @ ? rpm
Torque : ? ft·lbf (? kg/m, ? Nm) @ ? rpm
VTEC Switchover : 5700 rpm
ECU Code: PDN-A02
D16W7
VTEC-E
Found in:
2005-2007 Honda Civic Vti-L/ Vti (Asia)
Displacement:1,590 cc (97 cu in)
Compression : 10.9:1
Power : 115 hp (85.8 kW, 117 ps) @ 5600 rpm
Torque : 112 ft·lbf (15.5 kg/m, 152 Nm) @ 4300 rpm
Valvetrain : SOHC (? valves per cylinder)
Redline : 6100 rpm
Limit : 6200 rpm
ECU Code : PM12
Also found in 2001-2005 Honda Civic (Europe)
Same as above, except:
Power: 110 hp (82.0 kW, 81 kW) @ 5600 rpm
Redline 6100 rpm
Limit 6200 rpm
D16Y1
Found in
1992-1995 Honda Civic VTi (AUS)
Compression : 9.3:1
Power : 129 hp (96.2 kW, 131 ps) @ 6600 rpm
Torque : 107 ft·lbf (14.8 kg/m, 145 Nm) @ 5200 rpm
Redline : 7200 rpm
Valvetrain : SOHC VTEC (? valves per cylinder)
Head Code : P08
ECU Code : P28
D16Y4
Found in:
1996-2000 Civic i ES (Turkey-Turkiye-Techturkey)
1996-2000 Civic CXi,GL,GLi (New Zealand,Australia)
Compression : 9.4:1
Power : 120 hp (88.0 kW) @ 6400 rpm
Torque : 144 nm / 5000rpm
Redline : 6800 rpm
Rev-limiter: 7200 rpm
Head Code : P2A-2
ECU Code : P2K
Rod /Stroke Ratio : 1.52
Rod Length : 152 mm
Deck Height : 212
Gear Ratios:
1st 3.250 2nd 1.909 3rd 1.250 4th 0.909 5th 0.702 rev 3.153 final 4.058
D16Y5
VTEC-E
Found in :
1996-2000 Honda Civic HX
1996 Honda Civic EX(sedan Peruvian version)
Rod Length : 137 mm
Rod/Stroke : 1.52
Compression : 9.4:1
Torque : 104 ft·lbf (14.4 kg/m, 141 Nm) @ 4500 rpm
Valvetrain : SOHC VTEC-E (? valves per cylinder)
Head Code : P2J
1996-2000 VTi (Phils. & NZ)
Compression : ?:?
Power : 127 hp (94.7 kW, 129 ps) @ 5800 rpm
Valvetrain : SOHC VTEC(4 valves per cylinder)
Head Code : P2J
ECU Code : P2M
Piston Code : P2MY
D16Y7 (non-vtec)
Found in:
1996-2000 Honda Civic DX/VP/LX/CX
1999-2000 Honda Civic Special Edition - SE(Canada)
1996-97 Honda del Sol S
1997 Honda Civic Coupe LSI
Displacement : 1,593 cc (97.2 cu in)
Compression : 9.4:1
Power : 106 hp (79.0 kW, 107 ps) @ 6400 rpm
Torque : 103 ft·lbf (14.3 kg/m, 140 Nm) @ 4,600 rpm
Redline : 6800 rpm
Head Code : P2F
Piston Code : P2E
ECU Code : P2E
D16Y8 / D16Y6
VTEC
Also available in New Zealand under the code D16Y6
Found in
1999-2000 Honda Civic SE 1.6 Vtec (UK)
1996-1999 Honda Civic EX Sedan
1996-1999 Honda Civic EX Coupe
1996-2000 Honda Civic EX (US)
1996-2000 Honda Civic SI (Canada Only)
1997-2000 Acura 1.6EL (Canada Only)
1996-1997 Honda del Sol Si
1997-2000 Rover 416 Auto
Displacemnt : 1590cc
Rod Length : 137 MM
Rod/Stroke : 1.52
Compression : 9.6:1
Valvetrain : SOHC 4 valves per cylinder
Power : 127 hp (94.7 kW, 129 ps) @ rpm
Torque : 111 ft·lbf (45.79 kg/m, 145.1 Nm) @ rp
Head Code : P2J
Piston Code : P2P
Redline 7200 rpm
ECU Code : P2P
D16Y9
non vtec
Found in:
1996-2000 Honda Ballade, Honda Civic in South Africa and Venezuela
Compression : 9.2:1
Power : 106 hp (79.0 kW, 107 ps) @ 5900 rpm (Mt 110 hp (82 kW) @ 5500 rpm)
Torque : 108 ft·lbf (14.9 kg/m, 146 Nm) @ 4000 rpm
Fuel Control : OBD2A MPFI
ecu p2k 2 connectors vtec shortopen at?
The D16Y9 in South Africa has different power figures:
Power: 89Kw (119hp) @6400rpm
Torque: 146Nm (108 lbf-ft) @5500rpm
Information found in April 1998 CAR Magazine(SA)
D16Z5
(Basically the same engine as the D16A9, but now with a catalytic converter and lambda sensor)
Found in:
1988-1992 Honda CRX (European Market)
Compression : 9.5:1
Power : 124 hp (92.5 kW, 126 ps) @ 6800 rpm
Torque : ? ft·lbf (? kg/m, 140 Nm) @ 5600 rpm
Cam Gear : 34 tooth
Fuel Control : OBD-0 PGM-FI
Head Code : P7
Piston Code : PM7
ECU Code: PM7
D16Z6
Found in
1992-1995 Honda Civic Si
1992-1995 Honda Civic EX, EX-V
1992-1995 Honda Civic ESi (European Market)
1993-1995 Honda Del Sol Si (US)
1993-1995 Honda Del Sol ESi (European)
Rod Length : 137MM
Rod/Stroke : 1.52
Compression : 9.2:1
Power : 125 hp (93.2 kW, 127 ps) @ 6600 rpm
Torque : 106 ft·lb (14.7 kg/m, 144 Nm) @ 5200 rpm
Volumetric Efficiency : 87.68%
Redline : 7200 rpm
Fuel Cut : 7411 rpm
VTEC Switchover : 4800 rpm[3]
Head Code : P08
ECU Code : P28
D16Z9
Found in:
1994-1995 Civic Coupe (EJ1) 1.6i ESi European
Compression : 9.2:1
Torque : 106 ft·lbf (14.7 kg/m, 144 Nm) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7500 rpm
ECU Code : P28
D17 Series Engines (1.7 Liters)
D17A 2001-2005 (Japan) honda civic
Displacement : 1,668 cc (101.8 cu in)
Bore and Stroke: ?
Power : [lean burn] 115 hp (85.8 kW, 117 ps) @ ? rpm; 130 hp (96.9 kW, 132 ps) @ ? rpm
please find more info, there is also a D15B VTEC from this family with coils
D17A1
Found in:
2001-2005 Honda Civic DX/LX/VP
Bore and Stroke : 75 mm × 94.4 mm (3.0 in × 3.7 in)
Compression : 9.5:1
Power : 115 hp (85.8 kW, 117 ps) @ 6100 rpm
Torque : 110 ft·lbf (15.2 kg/m, 149 Nm) @ 4500 rpm
Fuel Control : OBD-2 MPFI cut: 180kmh
D17A2
VTEC-E
Found in:
2001-2005 Honda Civic EX (US only)
2001-2005 Honda Civic LX (Europe)
2001-2005 Honda Civic Si (Canada only)
2001-2005 Acura 1.7 EL (Canada only)
Bore and Stroke : 74.98 mm × 94.4 mm (2.952 in × 3.717 in)
Rod Length : 137 mm
Rod/Stroke : 1.48
Compression : 9.9:1
Power : 127 hp (94.7 kW, 129 ps) @ 6300 rpm
Torque : 114 ft·lbf (15.8 kg/m, 155 Nm) @ 4800 rpm
RPM redline: 6800 rpm
Rev-limiter : 7200 rpm
VTEC Switchover : 3200 rpm
D17A6
VTEC-E
Found in:
2001-2005 Honda Civic HX
Compression : 9.9:1
Power : 125 hp (93.2 kW, 127 ps) @ 5800 rpm &
Torque : 111 ft·lbf (15.3 kg/m, 150 Nm) @ 3800 rpm
Valvetrain : SOHC VTEC-Ec (4 valves per cylinder)
VTEC Switchover : 4400rpm
D17A7
Found in:
2001-2005 Honda Civic GX
Fuel CNG (Compressed Natural Gas)
Power : 100 hp (74.6 kW, 101 ps) @ 6100 rpm
Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 4000 rpm
Page 1 of 1
D Series engine specs + ostale info.....
Page 1 of 1
Sign In
Register
Help
Forums
Members
Help
Calendar
Search
Back to top
MultiQuote
