Tehnički podaci nekih VTi modela civica
3 replies to this topic
#1 Guest_deny_*
Guest_deny_*
  • Guests
Posted 07 June 2008 - 19:07
1990 Honda Civic 1.6i-VT
Bodywork
Type: 4/5S HBK
Number of doors: 0
Dimensions
Wheelbase: 2500 mm 98.42 in
Length: 3965 mm 156.10 in
Width: 1690 mm 66.53 in
Kerb weight: 1038 kg 2288.39 lb
Aerodynamics
Drag coefficient: 0.33
Engine
Type: 4-S
DOHC
4 valves per cylinder
Bore x stroke: 81.00 mm. × 77.40 mm.
Bore / stroke ratio: 1.04
Displacement: 1595 cc 97.33 cu in
Compression: 10.2
Fuel system: Ho PGM-Fi fuel inj.
Aspiration: Normal
Max. output: 152 PS (150 bph) (111.8 kW) @ 7600 rpm
Max. torque: 144 Nm (106.2 lbft) (14.6 kgm) @ 7100 rpm
Coolant: Water
Specific torque: N/A
Performance
0-60mph: 7.6 s
Quarter mile: 16.1 s
Top speed: 204
Chasis
Engine location: Front
Engine alignment: Transverse
Suspension front: I.DW.CS.
Suspension rear: I.DW.CS.
Transmission: 5M
Drive: F
1990 Honda Civic CRX 1.6i-VT
Bodywork
Type: 2+2 FHC
Number of doors: 3
Dimensions
Wheelbase: 2300 mm 90.55 in
Track front: 1453 mm 57.20 in
Track rear: 1453 mm 57.20 in
Length: 3774 mm 148.58 in
Width: 1674 mm 65.90 in
Kerb weight: 1025 kg 2259.73 lb
Weight distribution F/R: 64 %
Fuel capacity: 45 l 11.88 US gal
Aerodynamics
Engine
Manufacturer: aluminium alloy block & head
Type: 4-S
Wet sumped
DOHC
Compression: 10.2
Aspiration: Normal
Catalytic Converter: N
Coolant: Water
Performance
0-50mph (80 km/h): 6.2 s
0-60mph: 8 s
0-100mph: 22.1 s
Quarter mile: 16.4 s @ 89 mph
Kilometre: 29.6 s @ 180 km/h
Top speed: 209
Chasis
Steering: rack & pinion
Turns lock-to-lock: 4.1
Suspension front: I.DW.CS.ARB.
Suspension rear: I.DW.ARB.
Wheels F/R: 5.5 x 14 / 5.5 x 14
Tyres front: Dunlop D87 195/60 VR 14
Tyres rear: Dunlop D87 195/60 VR 14
Brakes: VeDi/Di-S
Brake diametre: 241/239 mm
Transmission: 5M
Drive: F
Top gear ratio: 0.87
Final drive ratio: 4.13
1992 Honda Civic CRX VTi
Bodywork
Type: 2+2 FHC
Number of doors: 0
Dimensions
Wheelbase: 2370 mm 93.30 in
Track front: 1475 mm 58.07 in
Track rear: 1465 mm 57.67 in
Length: 4005 mm 157.67 in
Width: 1695 mm 66.73 in
Kerb weight: 1105 kg 2436.10 lb
Engine
Type: 4-S
DOHC
Main bearings: 5
Compression: 10.2
Aspiration: Normal
Catalytic Converter: Y
Max. output: 162.2 PS (160 bph) (119.3 kW) @ 7600 rpm
Max. torque: 150 Nm (110.6 lbft) (15.2 kgm) @ 7000 rpm
Coolant: Water
Performance
0-60mph: 8 s
Top speed: 212
Chasis
Suspension front: I.W.CS.ARB.
Suspension rear: I.W.CS.ARB.
Brakes: VeDi/Di-S-ABS
Transmission: 5M
Drive: F
Final drive ratio: 4.26
1992 Honda Civic VTi HB
Bodywork
Type: 4/5S HBK
Dimensions
Wheelbase: 2570 mm 101.18 in
Length: 4080 mm 160.62 in
Kerb weight: 1080 kg 2380.98 lb
Engine
Type: 4-S
DOHC
Main bearings: 5
Compression: 10.2
Aspiration: Normal
Coolant: Water
Performance
0-60mph: 7.3 s
Quarter mile: 15.8 s
Top speed: 212
Chasis
Suspension rear: I.CS.W.ARB.
Transmission: 5M
Drive: F
1992 Honda Civic VTi Sedan
Bodywork
Type: 4/5S SAL
Number of doors: 4
Dimensions
Wheelbase: 2620 mm 103.14 in
Length: 4405 mm 173.42 in
Kerb weight: 1118 kg 2464.76 lb
Engine
Type: 4-S
DOHC
Main bearings: 5
Compression: 10.2
Aspiration: Normal
Coolant: Water
Performance
0-60mph: 7.7 s
Top speed: 216
Chasis
Transmission: 5M
Drive: F
#2 KKK
KKK
    ... mrzim rasizam ...
  • 5,264 posts
  • Vozilo:Accord 2.0 sport
Posted 07 June 2008 - 22:37
A za 6 generaciju???? :whistle:
#3 Guest_deny_*
Guest_deny_*
  • Guests
Posted 07 June 2008 - 22:48
biti ce..moram potraziti. planiram pokriti dosta modela kroz neko vrijeme.
#4 KKK
KKK
  • 5,264 posts
Posted 07 June 2008 - 22:50
Good :friends:
