Bodywork
Type: 4/5S SAL
Number of doors: 4
Dimensions
Wheelbase: 2675 mm 105.31 in
Track front: 1509 mm 59.40 in
Track rear: 1522 mm 59.92 in
Length: 4585 mm 180.51 in
Width: 1750 mm 68.89 in
Ground clearance: 152 mm 5.98 in
Kerb weight: 1405 kg 3097.49 lb
Fuel capacity: 65 l 17.17 US gal
Engine
Type: 4-S
DOHC
4 valves per cylinder
Bore x stroke: 87.00 mm. × 90.70 mm.
Bore / stroke ratio: 0.95
Displacement: 2157 cc 131.62 cu in
Compression: 11
Fuel system: Honda PGM-FI fuel inj.
Aspiration: Normal
Catalytic Converter: Y
Max. output: 211.8 PS (209 bph) (155.8 kW) @ 7200 rpm
Max. torque: 215 Nm (158.5 lbft) (21.9 kgm) @ 6700 rpm
Coolant: Water
Specific torque: N/A
Performance
0-100km/h: 7.2 s
Top speed: 228
Chasis
Engine location: Front
Steering: rack & pinion PAS
Turns lock-to-lock: 2.8
Turning circle: 12.1
Suspension front: I.DW.ARB.
Suspension rear: I.DW.ARB.
Wheels F/R: 7J x 17 / 7JJ x 17
Tyres front: 215/45 R 17 87W
Tyres rear: 215/45 R 17 87W
Brakes: VeDi/Di-S-ABS
Brake diametre: 300/260 mm
Transmission: 5M
Drive: F
Top gear ratio: 0.87
Final drive ratio: 4.26
